davidk1952
Feb 12, 2023Luminary
Netgear Nighthawk 2350 v1 router set up question with intel AC9260 in notebooks
 We are on Spectrum 500Mps down 20 up and for the most part everything is working great up to a few days ago, it seems like  we are getting a lot of DNS errors, can't find the site, sometimes windows ...
davidk1952
Hope this answers your questions
It is a Netgear Nighthawk x4 ac2350 Smart Wifi and it is the V1 ( I am told V2 is a bit different. We bought the router in about 2017
Router Firmware Version V1.0.0.124
It is a Spectrum cable Modem we have had for 4+ years
Parental controls Not on
Dynamic Qos not turned on
My genie app shows 36 devices
7 are 5g
4 are 2.4
The rest are hard wired
I don't see where I'd see the IPV6?
On the notebook is show no internet access IPV6 connectivity.
I don't think IPV6 has ever been on...
This issue has only started to be a real problem from about 1 -2 weeks ago.
Feb 12, 2023Guru - Experienced User
1. what actual spectrum modem is it? model is what I'm looking for.
2. Again, AC2350 isn't a model. Its a wireless speed. The only Router I could find with AC2350 and matching firmware is the R7500. Take a look at your label. Is that what you have? If so, you're actually a bit behind on the firmware. 1.0.0.130 is the newer one.
3. try enabling ipv6.
https://kb.netgear.com/24006/How-do-I-set-up-an-IPv6-Internet-connection-on-my-Nighthawk-router
4. If none of that helps, try a factory reset. Sometimes old settings can cause issues.
- davidk1952Feb 12, 2023LuminaryThe Netgear application does not support my router... it specifically says it does not support the R7500 - FURRYe38Feb 12, 2023Guru - Experienced UserTry updating the router using the router web page with a wired PC and web browser: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router FYI: - davidk1952Feb 12, 2023LuminaryGot it, thanks for the info, strange that the router didn't do the upgrade it is set to Auto, I want to look at the history of fixes and see if it has anything to do with my concerns... sometimes you create more issues than fix them. the issue they show for 30 is regarding apple time machine that I don't care about .... Ill. look at what else... .it does look like if I do a firmware upgrade I have to do a set up again, so I don't have time to do that today... but I'll look in to it. I'll post once I get it squared away.
