davidk1952
Feb 23, 2023Luminary
Netgear Nighthawk 2350 v1 router set up question with intel AC9260
Just trying to make things work better and I know a lot of you folks on here have dealt with this... I know I've got a lot of questions but better to ask a pro than try to sort through Page after pa...
Feb 24, 2023Guru - Experienced User
That router's 5ghz is a 4x4 antenna that supports "up to 1733mpbs". so 433mpbs over each antenna. That intel card is a 2x2 antenna device. So its max connection link is 866mpbs. Actual throughput (your actual speed) tends to be 55-65% of link speed. So you should be able to get 500mbps ish out of it. Try changing what channel you're on. Also make sure to test at close range as 5ghz speeds drop of quickly with distance/obstruction.
I would stick the AX210 card in the laptop. It won't hurt anything to have it installed.
- davidk1952Feb 24, 2023Luminary
Piemans, Thanks so much for your input... I've been testing a few MTU speeds on the 5G band and I put in 1468 this morning and am seeing a speed of Almost 450 down and I think it will go higher once everything settles in... Amazing what a few tweaks can do. Spectrum only has 20mbps up and I am passing that. I'm sitting about 20' from the router.
When I run my ethernet cable I am at almost 560mbps down... rock solid.
I have been doing a lot of testing lately because I am waiting to find out if I can get fiber to our house...united communications is starting to hang fiber (we live in the country) and have only had Spectrum up to now and I have the 500mbps service.
In anticipaton of getting 1GB fiber I have been looking at new Wifi 6 router set ups ( I have read many tech reports on the Mesh type set ups but I think I'll pass... we have Cat 5 running to all the rooms and I have 99% of our devices connected to Ethernet and we actually only have a handful of Wifi connections. Saying that... in 2005 when we built this house all cable installed was Cat 5 and not Cat 5e so the down fall is that I am seeing a limit on the device to device transfers to items like my NAS units that are hardwired. I know folks say I need to change the cable... No way, it's a 5,000 sq ft house and all cables are already run and I am not about to try to change them at this point... The one area we seem to spend most of our time and use the wifi happens to be about 20' from the router so I am thinking if I get a Wifi 6 router I can at least run Cat 6e to the new router from the fiber and get the use of the wifi locally.
The Intel card should be here today and I'll try to change it out this weekend... but the limit will be the current router... it seems that Netgear never offered a 4x4 client to take advantage of the 4x4 router design... and with that I'm capped at 1730 at this point. I am thinking by going at least Wifi 6 I will get a bit more speed on my Wi-Fi
- plemansFeb 24, 2023Guru - Experienced User
Netgear doesn't make the wifi cards/chipset. Those tend to be intel/qualcomm etc. There were a few 4x4 cards made but there were pretty expensive. The 2x2 devices do fine.
Its nice to shoot for faster speeds but its something to keep in mind the cost/benefit ration. Most streaming services only need 25-40mbps to stream 4k. So the vast majority of people don't really see much speed difference once you're above that 300+mbps unless you truly have a ton of streamers in the home. The only reason I have gigabit speeds is for testing routers and my media server. Or I'd be dropping my down.
Just something to keep in mind since you're hitting pretty decent speeds.
I would watch for mesh systems when you do upgrade based off the size of your home. I didn't think it'd make a difference in my home (3.2K ft) but it did. Much better coverage at the peripheral. And your home is even bigger than mine. It doesn't have the same peak performance of flagship routers when you're close to the router but at the edges, its much faster and more stable.
It might be worth holding off a little on purchase if your current device is working well as we're starting to see talk of wifi 7 routers. Not saying to buy one but when they start being released, you tend to see the wifi 6 stuff marked down a bit. Might get a 8 or 9 series orbi for pretty reasonable
Your right on the cards, I knew it was Intel and if Netgear every offered something it probably would have been with Intel chips...
We have kind of a crazy set up.... actually all the rooms upstairs are hard wired and we are not up there often enough to worry... our router is so locally positioned in the middle of the house we get acceptable levels for the little wifi use we need. We have a recording studio that is the whole floor above our dethatched garage...right now I just had a cat 5 cable installed and put a Wifi AP out there for folks that come in and to connect to our HVAC controller ... I'll keep a look out on the Orbi systems but like I said it may be more than we need (it's just my wife and I) all or media run on hard cable connections. With just the 2 of us, we are probably way over kill anyway...
We have the Fiber company offered us 1 gig up and 1gig down for 49.00 per month for 3 years .. .my 500mbps spectrum cable is now 80 per month going to $100 in august so, hopefully we can get the fiber in before any price increases... As for use... with the studio from time to time I have some HUGE files to transfers to other studios from time to time and with a limit on 20mbps upload it is a hassle, with fiber it will no doubt make that chore a lot quicker to complete.
I see you have the Nighthawk RAXE500, that was one of the routers I am looking at... I probably would not need the E, but just a Wifi 6 but then again having the 6E may be interesting to experiment with. The Intel AX210 is compatible with 6E correct... it would give me some options.
I'm usually not a new adopter as you can see... so, Wifi 7 isn't something I'd jump in to at this point.
