pegasokra's avatar
pegasokra
Netgear nighthawk 5ghz wifi speed extremely slow
I pay for 200 mbs download speed with spectrum. Im connected to a spectrum modem which connects to my netgear router, from that router i connect an ethernet cable directly to my computer, this connection results with appropriate speeds. The problem is on my 5g wireless connection i get 20-30 mbs download but still get the 10 upload. I dont know if i do not have the optimal settings for my specific router or not but to me it seems like it is way to slow. I have tried several different channels and it has came back with the same results need help asap.
1 Reply
  • FURRYe38's avatar
    What model NG router do you have?
    Is smart connect, MIMO and Beamforming enabled?
    What wireless devices are you testing with?
    How close are you to the router when speed testing?
    Ethernet wired speed tests results in good speeds?
