ackron16's avatar
Aug 11, 2022
Netgear Nighthawk 6700v3 Internet continues to cut out randomly on devices
Hi! Currently we're running into an issue where it seems our router is causing our devices to randomly disconnect or barely get any type of internet speed. We have our speeds were, on average, between 800-900mbps but now suddenly drop to 80 mbps or just straight disconnect.  It's already happened on both sets of wi-fi (the 5ghz and 2.4ghz), as well as the direct connection devices we have.  I'm also currently on Firmware Version V1.0.4.128_10.0.104. Any help would be greatly appreciated.
  • plemans's avatar
    Thats a new firmware in the last couple days. Have you tried a factory reset/reinstall?
    If not, start there.
    If you have, try downgrading the firmware.
    During the install, make sure to leave qos, access control, traffic monitoring, and parental controls disabled.
    (pretty sure the 800+ speeds were wired as you won't hit that over wireless on that router)
    • ackron16's avatar
      ackron16
      Tutor
      Thank you for the help plemans !
      I have, that was actually how I got it to originally work.  I needed to factory reset it to even get into the set up page.
      How would I go about do that? I'm willing to try anything at this point.  Also all those settings that you listed are currently disabled. (You're correct about the 800+ speeds, there were on the wired test)
      • plemans's avatar
        Downgrading the firmware is pretty simple.
        You download it from the support site. Under downloads---->view previous versions
        Then extract that file.
        then follow the manual update process (from the manual) and instead of using the newer firmware, use the older firmware.
        After it reboots, I recommend factory resetting it. Anytime you downgrade firmware, thats a step I'd recommend.
        the 80mbps is the max you can expect from 2.4ghz but the 5ghz should be faster if you're getting faster wired speeds.
        You can try disabling smart connect so you can control if you're connected to the 2.4ghz or the 5ghz.
