Hans-Brinker
Jul 21, 2017Aspirant
Netgear Nighthawk 7000 Tomato Flashing
I want to install a VPN on my network. I was advised to install Tomato firmware on my router. My first question is: Is my router compatibel with Tomato? It indicates that it is compatibel with Netg...
- Jul 21, 2017
Your title says R7000 but you have selected R7800 in product.
yes R7000 support but not R7800. As both are differet SOC. procy so the later wont support and it is different architecture altogether.Hope this clarify the query. You can install vpn but using Custom firmware but alike stock from Voxel. Search on SNB forum
Its most updated robust firmware built for comunity.
mondenath
Jul 21, 2017Prodigy
Hans-Brinker
Jul 22, 2017Aspirant
mondenath wrote: You can install vpn but using Custom firmware but alike stock from Voxel. Search on SNB forum, Its most updated robust firmware built for comunity.
I don't uderstand what you mean excactly by this . Please explain.
