VTMartha1's avatar
VTMartha1
Netgear Nighthawk 8500 can't log in to change settings
Hello, I have a Netgear Nighthawk 8500 which seems to be working fine.  I'd like to share a usb drive on it but not having much luck.  Using the Netgear genie, I cannot log in to the router so I can...
