DrJZM
Feb 06, 2024Follower
Netgear Nighthawk A1900 R7000 Losing internet connection, losing ip address
My router losses internet connection randomly also again and again, to get it working I have to reset my router by pressing hard reset button on the back of the router. As soon as I lose internet...
Feb 06, 2024Guru - Experienced User
Does the top Internet LED turn AMBER when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
hat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
