mdross1
Oct 18, 2022Aspirant
Netgear Nighthawk AC1750 Smart wifi. model # R6700v3
Hi, Our current wifi is horrible a lot of lost calls. Really anxious to install this Netgear because of alll the other changes that have to happen with it. We are not computer people. Was hoping we...
Oct 18, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
You and use same SSID name and Password from your old wifi router if you like.
mdross1
Our provider is Spectrum using their modem and latest wifi 6 router. Everything else you mentioned would need help with. Thank you for the reply.
