TatoGuam
Mar 02, 2025Follower
Netgear Nighthawk AC1900 Model R7000 DEAD
Router just died, no power, nothing. Power adapter is working, as i used it to power up another router, so it’s not the power adapter. Is there a fuse that could have blown, that I can replace myse...
Mar 04, 2025Guru - Experienced User
Probably long out of warranty. Might as well open it up and see if there's anything obviously broken. I had a kid knock my RAX200 off a shelf and break the power jack. Simply soldered the power wire back on and its been working for years.
