inigam
Aug 02, 2023Aspirant
Netgear Nighthawk AC1900 R7000 - Router mgmt page does not load + cant make change / update firmwr
I have a R7000 router using it with UK Virgin Hub 3.0 modem mode. in modem mode Virgin Hub is giving super speeds when wired as expected. however this Netgear R7000 router connected with modem is ...
inigam
Hello many thanks for your response.
Apologise as it was a typo and I was actually getting the page to load anyway using the correct address.
The issue main is, however, that page isnt loading all the content completely. I can see left hand navigation and some buttons and check boxes but no text and it never loads anything more and browser tells the loading is complete.
michaelkenward
Aug 02, 2023Guru - Experienced User
And the reset?
Try a different browser.
Connect a PC directly to the R7000 without any connection to the modem.
