vandervecken
Apr 18, 2021Aspirant
Netgear nighthawk AC1900
I want to change the firmware on my modem/router but there is no update button. Model is AC1900. This is MY modem/router, not the ISP's. So shouldn't a button so I can update be visible to me? I am u...
Kitsap
Apr 18, 2021Master
First of all, AC1900 is not a model number. It is a speed. Look at the tag on the router, The model number most likely starts with a C for cable or D for DSL.
Although it is YOUR router, the ISP allows it to be connected to THEIR system. When an ISP allows a router to be connected to THEIR system, THEY control the firmware.
If you care to continue, the model number of your router and the name of your ISP would be helpful.
antinode
Apr 18, 2021Guru
Cropping to exclude the actual model number did no one a favor.
> [...] this is MY modem/router, not the ISP's.
Doesn't matter.
https://kb.netgear.com/000036375
> [...] When an ISP allows a router to be connected to THEIR system,
Not really. First, you probably meant "modem", not "router". Even
in a DOCSIS environment, after the modem, the user can connect any
router he wants. (Although with a combined modem+router, connecting
anything immediately after the modem can be difficult.)
Second, a DOCSIS (typically cable-TV) ISP controls the firmware of
connected devices; a DSL ISP generally does not.
- vanderveckenApr 18, 2021Aspirant
I didn't crop to exlude the model number. I wasn't even considering the model number when I took the shot.
Jeeze I will NEVER ask for help here again. None of you has an ounce of simple, normal courtesy in you.
