vandervecken
Apr 18, 2021Aspirant
Netgear nighthawk AC1900
I want to change the firmware on my modem/router but there is no update button. Model is AC1900. This is MY modem/router, not the ISP's. So shouldn't a button so I can update be visible to me? I am u...
antinode
Apr 18, 2021Guru
Cropping to exclude the actual model number did no one a favor.
> [...] this is MY modem/router, not the ISP's.
Doesn't matter.
https://kb.netgear.com/000036375
> [...] When an ISP allows a router to be connected to THEIR system,
> THEY control the firmware.
Not really. First, you probably meant "modem", not "router". Even
in a DOCSIS environment, after the modem, the user can connect any
router he wants. (Although with a combined modem+router, connecting
anything immediately after the modem can be difficult.)
Second, a DOCSIS (typically cable-TV) ISP controls the firmware of
connected devices; a DSL ISP generally does not.
vandervecken
I didn't crop to exlude the model number. I wasn't even considering the model number when I took the shot.
Jeeze I will NEVER ask for help here again. None of you has an ounce of simple, normal courtesy in you.
