brooms1
Oct 29, 2022Follower
Netgear NightHawk AC1900
I am trying to connect an irobot to the internet. It says it can't connect because it uses a 2.4 signal. I have tried switching speeds on the router, but that doesn't work. Any ideas?
Oct 29, 2022Guru - Experienced User
1. what router do you have? AC1900 is a speed
2. Did you make sure you're phone is connected to 2.4ghz during setup? Thats what its asking you to do (basically)
