brooms1
Oct 29, 2022Follower
Netgear NightHawk AC1900
I am trying to connect an irobot to the internet. It says it can't connect because it uses a 2.4 signal. I have tried switching speeds on the router, but that doesn't work. Any ideas?
michaelkenward
Oct 30, 2022Guru - Experienced User
You are not alone:
Search - NETGEAR Communities – irobot
- plemansOct 30, 2022Guru - Experienced User
michaelkenward some have had issues. I've connected 2x different irobots to my network without issues.
Shouldn't say zero issues because it had issues with wpa3 but once security was changed to wpa2/wpa3, zero issues
- michaelkenwardOct 30, 2022Guru - Experienced User
My point was that someone who turns up here with a question might find it useful to see what has been said about it before.
I am amazed by the number of people who don't try that simple troubleshooting move before they throw a "new" problem into the mix.
