bcw123
Mar 30, 2023Aspirant
NETGEAR Nighthawk AC1900
When I try and login to the router via http://routerlogin.net it is getting changed to replace http to https ending here instead https://www.routerlogin.net/
Mar 30, 2023Guru - Experienced User
cool.
Is it causing problems?
Are you having an issue with something?
