Joegsi
Aug 08, 2021Follower
Netgear nighthawk AC1900/R7000 flashing power light
Hi there, I have an AC1900 which has been working fine. I recently went on holiday and on my return it no longer works and the power led flashes white constantly. The router was not touched or switch...
Aug 08, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
