BladeParker
Aug 25, 2019Aspirant
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200 how to fix?
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200. Anyway to fix this?
- Aug 26, 2019
> [...] why is the Nighhawk port orange? [...]
A bad cable could do it. Connect the ends of that cable to any two
LAN Ethernet ports on the R7000P. Do the two corresponding port-status
indicators show white or amber?
BladeParker
...and I am already aware of this: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Orange-Red-light-on-my-netgear-nighthawk-router/m-p/1595975#M97353
If the device you connected is only capable of 10/100 Mbps Fast Ethernet LAN connection, the LAN port lights amber to show.....
- BladeParkerAug 26, 2019Aspirant
Here it is, thanks.
R7000P
- IrvSpAug 26, 2019Master
Did you read the link? 10/100Mbps cable into the port, and that can be ANY cable, it is the device at the other end that determines the connection.
Still, no information which LED is orange... I assume it is one of the 4 ports?
The Powerline Adapter can connect at 1Gb, so the problem is either:
- Cable being used.
- Port on router bad, try another.
- Powerline adapter bad.
- michaelkenwardAug 26, 2019Guru - Experienced User
As IrvSp says, the most important detail is missing.
Which LED?
The device does matter, but the LED array is usually similar on most modern kit.
Oh, and what is going wrong that makes you ask about the LED?
Something not connecting? Going slow? Throwing up errors?
This is my understanding as to WHY it is orange. "If the device you connected is only capable of 10/100 Mbps Fast Ethernet LAN connection, the LAN port lights amber to show that it is connected at a slower speed than what is supported by the router. If your device has a Gigabit Ethernet port, the LAN port lights white."
The Powerline 1200 should be well above 10/100. It is listed as, "10/100/1000Mbps Gigabit Ethernet port" Hence the question, why is the Nighhawk port orange? All other LAN port lights are white as expected.
