BladeParker
Aug 25, 2019Aspirant
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200 how to fix?
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200. Anyway to fix this?
- Aug 26, 2019
> [...] why is the Nighhawk port orange? [...]
A bad cable could do it. Connect the ends of that cable to any two
LAN Ethernet ports on the R7000P. Do the two corresponding port-status
indicators show white or amber?
michaelkenward
Aug 26, 2019Guru - Experienced User
Which AC2300? Which orange light?
AC2300 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
The R7000P, one AC2300, has about a dozen LEDs on the top. Several of them have an "Amber" setting.
