BladeParker
Aug 26, 2019Aspirant
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200 how to fix?
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200. Anyway to fix this?
- Aug 27, 2019
> [...] why is the Nighhawk port orange? [...]
A bad cable could do it. Connect the ends of that cable to any two
LAN Ethernet ports on the R7000P. Do the two corresponding port-status
indicators show white or amber?
BladeParker
...and I am already aware of this: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Orange-Red-light-on-my-netgear-nighthawk-router/m-p/1595975#M97353
If the device you connected is only capable of 10/100 Mbps Fast Ethernet LAN connection, the LAN port lights amber to show.....
BladeParker
Here it is, thanks.
R7000P
