BladeParker
Aug 26, 2019Aspirant
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200 how to fix?
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200. Anyway to fix this?
- Aug 27, 2019
> [...] why is the Nighhawk port orange? [...]
A bad cable could do it. Connect the ends of that cable to any two
LAN Ethernet ports on the R7000P. Do the two corresponding port-status
indicators show white or amber?
BladeParker
Here it is, thanks.
R7000P
IrvSp
Aug 26, 2019Master
Did you read the link? 10/100Mbps cable into the port, and that can be ANY cable, it is the device at the other end that determines the connection.
Still, no information which LED is orange... I assume it is one of the 4 ports?
The Powerline Adapter can connect at 1Gb, so the problem is either:
- Cable being used.
- Port on router bad, try another.
- Powerline adapter bad.
