BladeParker
Aug 26, 2019Aspirant
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200 how to fix?
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200. Anyway to fix this?
- Aug 27, 2019
> [...] why is the Nighhawk port orange? [...]
A bad cable could do it. Connect the ends of that cable to any two
LAN Ethernet ports on the R7000P. Do the two corresponding port-status
indicators show white or amber?
BladeParker
Here it is, thanks.
R7000P
michaelkenward
Aug 26, 2019Guru - Experienced User
As IrvSp says, the most important detail is missing.
Which LED?
The device does matter, but the LED array is usually similar on most modern kit.
Oh, and what is going wrong that makes you ask about the LED?
Something not connecting? Going slow? Throwing up errors?
- BladeParkerAug 26, 2019Aspirant
This is my understanding as to WHY it is orange. "If the device you connected is only capable of 10/100 Mbps Fast Ethernet LAN connection, the LAN port lights amber to show that it is connected at a slower speed than what is supported by the router. If your device has a Gigabit Ethernet port, the LAN port lights white."
The Powerline 1200 should be well above 10/100. It is listed as, "10/100/1000Mbps Gigabit Ethernet port" Hence the question, why is the Nighhawk port orange? All other LAN port lights are white as expected.
- antinodeAug 27, 2019Guru
indicators show white or amber? - michaelkenwardAug 27, 2019Guru - Experienced User
My Powerline PLP1200 show as a Gb connection on a 16-port dumb switch. So I second the cable hypothesis.
- BladeParkerAug 28, 2019Aspirant
It was the cable... :(
My appologies, I was certain I had tested that before. Thank you for all of the help!
