BladeParker
Aug 26, 2019Aspirant
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200 how to fix?
Netgear Nighthawk AC2300 orange light when connected to Netgear Powerline 1200. Anyway to fix this?
- Aug 27, 2019
> [...] why is the Nighhawk port orange? [...]
A bad cable could do it. Connect the ends of that cable to any two
LAN Ethernet ports on the R7000P. Do the two corresponding port-status
indicators show white or amber?
michaelkenward
Aug 27, 2019Guru - Experienced User
BladeParker wrote:
The Powerline 1200 should be well above 10/100. It is listed as, "10/100/1000Mbps Gigabit Ethernet port" Hence the question, why is the Nighhawk port orange? All other LAN port lights are white as expected.
My Powerline PLP1200 show as a Gb connection on a 16-port dumb switch. So I second the cable hypothesis.
BladeParker
Aug 28, 2019Aspirant
It was the cable... :(
My appologies, I was certain I had tested that before. Thank you for all of the help!
