BSarte
Jan 24, 2022Aspirant
Netgear NightHawk AX4 RAX40 Change LAN IP in Advanced Settings Does Not Work - Conflict
I just bought a Netgear Nighthawk AX4 RAX40 WiFi Router and am having an issue with changing the LAN IP address. I have a LAN in my home and the IP is 192.168.0.x. The new router LAN IP is 192.16...
BSarte
Jan 25, 2022Aspirant
Thanks for your replies.
I changed it ti AP mode and it is working fine, but I still need to be able to login to adjust some of the settings that I don't find on the Android App on my phone.
How can I change the LAN IP Setting so I can see the device on my network?
Jan 25, 2022Guru - Experienced User
log into your primary router and look at its attached devices list. It should list the AP router's ip address. Use that address to access it.
