Hibci
Nov 22, 2020Aspirant
Netgear Nighthawk ax4
I bought the Nighthawk RAX35 4-Stream Wifi 6 Router and hooked it up to my Modem. I also bought the Orbi whole home wifi system. Are they the same thing or can I hook them up together. And if they ar...
Hibci
Nov 23, 2020Aspirant
We bought the Nighthawk as the router and then we bought the Orbi as a range booster not knowing the Orbi was a router to. Which one is stronger and faster.
michaelkenward
Nov 23, 2020Guru - Experienced User
That's one of those questions that is impossible to answer. Different devices with different objectives aimed at different markets.
The RAX35 is likely to have more features as a router whereas the Orbi could do better wifi. It will also be simpler to use and set up.
