fabrownii718
Jan 05, 2021Aspirant
Netgear Nighthawk C7800 Locked Out
I purchase this modem/router off Ebay in September 2020. It was listed as open box. I have been using it since with Spectrum 1gb and has been fine. Today it started losing internet and seems to rebot...
- Jan 05, 2021
You can factory reset it and get everything back to default.
Simply push and hold reset for 7-15 seconds while its powered on.
Then you'd need to re-install it.
fabrownii718
What do you mean re-install it? I just plugged it in and used the SSID and password located on the back since I wasnt able to access anything.
Jan 05, 2021Guru - Experienced User
there's an install guide that lets you setup your own ssid/password plus other settings.
C7800 | Product | Support | NETGEAR
