lulajean
Dec 14, 2020Follower
NETGEAR Nighthawk Cable Modem WiFi Router Combo
I purchased this router for my 2,500 sq foot house. It should cover the whole house, but it doesn't, I blame the huge brick fireplace that runs the length of the house and blocks my office from most...
microchip8
Dec 14, 2020Master
Get Access Points (APs). If you can't run a cable, Powerline is a sound alternative though not as speedy
labatt
Dec 14, 2020Mentor
My house is only 1900sq ft, but I fought wireless signal issues for several years until I went with an AP solution over Ethernet. As mentioned a Ethernet over power adapter would work well if you cannot run Ethernet cable.
House is wet plaster over metal lath. So going through 2 layers of that in some cases and at least one layer. With AP's I have a solid wifi, wifi 6, with a recent upgrade. I did go to the more commercial side of things as I got fed up with the crap Netgear calls firmware. Make good hardware, so too bad they cannot make the firmware as good as the hardware.
