calypso1001
Aug 02, 2015Aspirant
Netgear Nighthawk D7000 SNMP support for MRTG
HI Folks I just replaced my old TPlink 1043ND and 8840T DSL modem with this D7000. Is there special menu to enable snmp on this modem/router combo. Below what I used to get on my old Tplink...
- Aug 03, 2015
Thanks you are right no DD-WRT for D7000 ADSL/VDSL modem. definitly not a R7000. Well let see if a port for D7000 turns up in the database.
TheEther
Aug 02, 2015Guru
I never knew the D7000 existed. Anyway, I think you are out of luck. I'm pretty sure that SNMP is not supported on stock firmware.
If you had a R7000, you could switch to 3rd party firmware, like DD-WRT, which supports SNMP.
calypso1001
Aug 03, 2015Aspirant
