Sayre68
Dec 13, 2021Aspirant
Netgear nighthawk disconnects from internet during online games after about 3 minutes
I like the nughthawk router and it works great except when im gaming online, i get disconnected every single time after about 3 minutes. It works fine when im streaming etc but every time kicks me off...
Dec 13, 2021Guru - Experienced User
What model NG product and model# are you referring too?
Does this happen with wired and wireless connections?
- Sayre68Dec 13, 2021Aspirant
This is a netgear ac1750. v1.1.0.84 is the firmware version.
The modem is an Arris cm820a.
Wireless works fine though of course that is not the best to game with.
This was an upgrade from a netgear n150 router. That worked fine but I was
no longer getting the full speed of the internet I have available with that.
Thanks for your response.
- FURRYe38Dec 13, 2021Guru - Experienced User
ac1750 is not a model #, thats a wifi connection rate number. R#### is a model #.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.- Sayre68Dec 13, 2021Aspirant
Oh yeah I see that now, R6350 model #
- Sayre68Dec 21, 2021Aspirant
I've tried those things and after discussion with other gamers, the recommendation was to set port setting to open and if that didnt work set up dns server. Tried those with no success. Switched back to my 10 year old netgear n150 router to test, works just fine.
- FURRYe38Dec 22, 2021Guru - Experienced User
