bruzogiri
Nov 02, 2023Follower
Netgear Nighthawk dropping 5G wifi connection - Fixed when restarted
Hi I was just wondering whether anyone else has experienced similar issues. I have my 5Ghz wifi connection connected to my desktop and recently noticed that it sometimes drops out. The 2.4ghz is st...
Nov 04, 2023Guru - Experienced User
michaelkenward is 100% correct.
More details are needed.
Router?
Firmware on it?
Gateway its connected to?
What 5ghz channels are you using? DFS channels can cause drops if you have radar/weather stations in the area (or anything else using dfs).
