scfung
May 06, 2021Aspirant
Netgear Nighthawk EX7500 interferes with Amazon Fire TV stick - weak signal
I bought this to extend the wifi signal from the router (in the sitting room) to the TV room/ office, in another room. My apartment is only 800 square feet, with one concrete wall in between. The ex...
May 06, 2021Guru - Experienced User
concrete is one of the best materials for blocking wifi.
You might be better off if you can use powerline or moca adapters to get the signal/connection through that wall.
- scfungMay 06, 2021Aspirant
Thank you for your concern, but the concrete wall is not the issue. When I unplugged the Nighthawk, the signal is absolutely fine.
I was looking for advice / comment why the Netgear Nighthawk would slow donw, rather than improve the signal of the Amazon Fire TV stick.
- plemansMay 06, 2021Guru - Experienced User
The EX7500 does band steering. Is it putting the fire stick on the 2.4ghz band? its more sensitive to interference than the 5ghz band.
I have done EVERYTHING! I used 2.4, 5, I switched it to my other networks including Apple Time Capsule, and amazingly the one that gives the best signal (still too low for TV) is my old BT dish! Not Vodafone (my router)!
