samenchav
May 12, 2023Follower
Netgear Nighthawk issues - am i overloading it?
Hey all, i'll try to keep this brief. I've recently moved in to a new house & have been in the process of smartify-ing it. We're running everything off a Netgear Nighthawk & no matter what i do, th...
May 12, 2023Guru - Experienced User
What model NG router do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What do you mean by "Several times a day *something* drops".
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
