tbaustin1992
Mar 10, 2021Aspirant
Netgear Nighthawk Keeps resetting randomly.
A few days ago my router started randomly what seems like rebooting itself. It happens at random so I don't think it's some reboot sequence or something. Yesterday it happend 3 times in a row within ...
Mar 10, 2021Guru - Experienced User
What actual router is it? you put a7000 in your signature which is a wireless usb adapter.
What firmware is on it?
Have you checked the power supply and the outlet? I've seen a loose outlet cause devices to reboot.
tbaustin1992
Mar 12, 2021Aspirant
It's a a7000 and I re plugged it into the wall, it has the newest software.
- antinodeMar 12, 2021Guru
> A few days ago my router [...]
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Not a router. Look for "Model" on the product label. Read
carefully. Type carefully. Read carefully what you've typed.> [...] what seems like rebooting itself. [...]
"seems like"? What is it actually doing?
> [...] it has the newest software.
Says who? As always, an actual version number would be more useful
than your opinion of what's "newest" today.- tbaustin1992Mar 13, 2021Aspirant
It is a Netgear Nighthawk, AC1900 Smart WiFi Router, model: R7000
When it happens every light is off except for the power light which is a solid amber. From research that means it is rebooting.
Firmware is V1.0.9.88_10.2.88. I keep hitting update and it says it has the latest.- antinodeMar 13, 2021Guru
> has the latest.Trust no one, I always say.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:(That paragraph was supposed to be part of my previous message, but I
apparently failed to include it. Oops.)No bets on whether that will help. You might be looking at a
hardware problem, too (router or power adapter).You might also try a settings reset, and manual reconfiguration. On
occasion, some settings info can get corrupted and cause odd problems.
