Sophyee's avatar
Sophyee
Follower
Apr 05, 2021
Netgear Nighthawk modem under $200 price?
Which one is the best Netgear Modem product and how long it will work efficinetly?
1 Reply
  • plemans's avatar
    Sophyee wrote:
    Which one is the best Netgear Modem product----The one that is compatible with your isp. That's key. You can buy netgears best modem but have it not be compatible. Did you check with your isp on compatible modems.
    and how long it will work efficinetly?---Until it goes bad. Sadly we can't predict that. You can do things to make it last longer like ensuring it has proper cooling/well ventilated (heat is death of electronics)
