yakulebak
May 05, 2022Follower
Netgear Nighthawk not getting full speeds from router
I pay for 400/mbs down because that is the best I can get in my area regretfully, but even if I could get Gig speeds, my router seems to be struggling even getting 140/mbs. I had a Spectrum tech c...
May 05, 2022Guru - Experienced User
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. how are you testing speeds? Wired? wireless? And if wireless is it over 2.4ghz/5ghz?
5. what device are you testing on (specifics to it)?
6. Did you try a factory reset and testing from stock (without enabling/changing anything)?
