KJ6EO58's avatar
KJ6EO58
Initiate
Jan 26, 2020
Netgear Nighthawk R-7000 Running Tomato Reverting To Factory Default Firmware
Hello and thank you for reading my post.     My Nighthawk R-7000 has been running on  Shibby Tomato Firmware for the last several years.  Due to a recent problem, I decided to  flash back to the  Fac...
  • shadowsports's avatar
    Jan 27, 2020
    Greeetings,
    As great as 3rd party FW can be, problems encountered when trying to go back to stock can be a pitfall.
    No one but you can try to solve this, because we are not there to know or see what happened.
    Suggestions:
    Try with another browser
    Try accessing using an IP
    TFTP reflashing relies on several things.  Correct execution and timing (primarily).  The reflash ""window" of opportunity is brief during boot and when missed, you have to start over.
    Open a command prompt and ping the router with a -t switch.  This will give you a continious ping to the router's "suspected" IP.
    Restart the device and look for the "reply" during the boot process.  This will tell you if your settings are correct and help to determine the state of the your device. After 2-3 starts, you will get a better feeling for the timing and can likely plan the execution of the re-flash.
    I ocassionally use two command prompts to help with timing (if needed).  One to watch for the reply, the other poised with the TFTP command "ready" to execute.
    Success is also going to depend on the hardware, its state, what happened to it when you removed the tomato FW, etc.
    Good luck
