Null_Sum
Jan 19, 2017Aspirant
Netgear Nighthawk R6700 periodic network disconnects
Hey all! I have a problem that I cant seem to fix, my router seems to be disconnecting every 40 -60 seconds and stays disconnected for around 10 -15 seconds, both wireless and hardline are doing the ...
- Jan 29, 2017
Hi Null_Sum,
Please try changing the MTU size of the router.
http://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
https://kb.netgear.com/24015/How-do-I-change-the-MTU-size-on-my-Nighthawk-router
Null_Sum
Jan 23, 2017Aspirant
OK so I reset router to factory defaults and still the same issue, I have also bypassed the router and the issue no longer happens
Null_Sum
Jan 28, 2017Aspirant
Still need help with this, i have done all of this and its still disconnecting
- JamesGLJan 29, 2017NETGEAR Employee Retired
Hi Null_Sum,
- JamesGLFeb 02, 2017NETGEAR Employee Retired
Hi Null_Sum,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
