Alex7898
Jul 06, 2017Initiate
Netgear Nighthawk R6700 VPN pass-through disconnects every 5 minutes
Hello, I have a problem with my R6700v2 new router. I use it in a pass-through mode to connect to my company VPN. The client device is MacOS. Every 4-5 minutes VPN got disconnected. My old Dlink ...
- Jul 11, 2017
Hi All,
If you happen to know the port number that your VPN is using, try to open it under port forwarding.
ashishrahurkar
Jul 10, 2017Initiate
I have the similar problem with R6700v2. It starts blocking internet and vpn access after some random time. Bypassing the routers and using LAN cable with the Netgear modem works perfectly fine.
JamesGL
Jul 11, 2017NETGEAR Employee Retired
Hi All,
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Alex7898Jul 20, 2017Initiate
Hello, I confirm that the issue has not been solved. Nighthawk disconnects from time to time when on VPN. Old Netgear router works fine with the same settings. Can we look for other sources or escalate the issue please?
