initialz23
Jan 15, 2018Aspirant
Netgear Nighthawk R6700v2 Disconnects Company VPN Every Several Minutes
Hi, I'm having this frequent disconnecting issue using Nighthawk router. I see other posts that describe a method about opening a port for VPN. 1. I don't know how could I find the port number of m...
- Jan 22, 2018
Hi initialz23,
Check with the VPN server provider for the port you need to use. When you go to port forwarding, look for Internal and external port box. Type in the port provided to you.
JamesGL
Jan 22, 2018NETGEAR Employee Retired
Hi initialz23,
JamesGL
Jan 28, 2018NETGEAR Employee Retired
Hi initialz23,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
