Netfear32-AR
Jul 06, 2022Aspirant
Netgear Nighthawk r6700v3 wifi speed capped
Hi, I've seen several other posts re: r6700v3 speed getting capped. Sounds like the best thing is to create a new post if I have the same issue so that Netgear sees that multiple users are experienc...
michaelkenward
Jul 06, 2022Guru - Experienced User
It is hard to follow what you are measuring here and how.
Netfear32-AR wrote:
....now getting 300+ mbps. Still not the 990 mbps I was seeing while directly connected to modem.
Is that 300 Mbps when wired to the router?
So far, all your references to "directly" seem to be wired to the modem rather than wired to the router.
Wifi connections will never get anywhere near 990 Mbps.
