NullStar
Oct 14, 2024Aspirant
Netgear nighthawk r6900p no internet
Hello all, my netgear nighthawk r6900p says it isn't connected to the internet even though the modem works. I have cycled the power multiple times to no avail is there anything I can do? This is the f...
NullStar
Oct 15, 2024Aspirant
Both my phone and smart TV say that there is no internet when connected over wifi and my desktop also says it when connected via ethernet.
michaelkenward
Oct 15, 2024Guru - Experienced User
None of these things can talk. There is something on these devices that gives that message.
Take the desktop, is it a browser? Is it the operating system?
Can the mobile devices see the SSID for the WiFi?
Just another user with time on their hands.
- NullStarOct 15, 2024AspirantBoth the phone and TV can connect but when I check the signal in the wifi settings it will say "connected without internet" on the computer it's says the same for the ethernet connection in the wifi settings
- michaelkenwardOct 15, 2024Guru - Experienced User
NullStar wrote:
when I check the signal in the wifi settings it will say "connected without internet"Where are you doing this?
on the computer it's says the same for the ethernet connection in the wifi settingsWhere on the computer does it say this?
- NullStarOct 15, 2024AspirantHere on my phone
