NullStar
Oct 15, 2024Aspirant
Netgear nighthawk r6900p no internet
Hello all, my netgear nighthawk r6900p says it isn't connected to the internet even though the modem works. I have cycled the power multiple times to no avail is there anything I can do? This is the f...
michaelkenward
Oct 15, 2024Guru - Experienced User
NullStar wrote:
when I check the signal in the wifi settings it will say "connected without internet"
Where are you doing this?
on the computer it's says the same for the ethernet connection in the wifi settings
Where on the computer does it say this?
Just another user with time on their hands.
NullStar
Here on my phone
