jhaiar's avatar
jhaiar
Initiate
Apr 13, 2021
Netgear nighthawk R6900P proper setup in AP mode
II am in process of setting my nighthawk router as an access point. Following the instructions in the Manual it says "To avoid interference with other routers or gateways on your network, we recommend...
  • plemans's avatar
    Apr 14, 2021
    so the 2.4ghz has 1-11 (in US) and the 5ghz has channels 32-48, 50-144 (dfs channels), and149-165
    List of WLAN channels - Wikipedia
    they want you putting the router on seperate channels so they're not interfering with each other.
    there is channel overlap so its good to seperate them out more than just 1 channel.
    Designing a Dual-Band Wireless Network | MetaGeek
    You can leave the ssids (names) the same if you'd prefer. When I'm running multiple networks, I tend to use different ssids so that I can choose which network to connect to as needed.
