CallmeBK's avatar
CallmeBK
Netgear Nighthawk R6900v2 Transmit Power
I see the setting to change transmit power... but it is given in terms of percentage.  Default is 100%.  What is the value of 100% in dBm for a Netgear Nighthawk R6900v2?
  • > [...] What is the value of 100% in dBm [...]
       "dBm" as measured by what, where?  Normally, a factor of two in power
    corresponds to about 3dB.
       Is there some actual problem which you are trying to solve?
          https://en.wikipedia.org/wiki/Decibel
    • CallmeBK's avatar
      CallmeBK
      1) 100% transmit power of 2.4 GHz signal
      2) 100% transmit power of 5 Ghz signal
      Do you know their values?
      • antinode's avatar
        antinode
        Guru
           No.  I'd guess that they're close to the maximum permitted by the
        relevant regulations.  If I really wanted to know, then I might open the
        box, identify the radio modules, and try to find their specs.  Assuming
        that you want the final-stage input power, and not what actually leaves
        the antenna.
           Still wondering.
