kill0708
Feb 18, 2023Aspirant
Netgear nighthawk r7000 - Firewall blocking macincloud
I downloaded macincloud, but it is not working on my system. Their support asked me to check my network firewall, but their is no firewall option for Netgear nighthawk r7000. Anyone know how to acess...
michaelkenward
Feb 19, 2023Guru - Experienced User
I'm afraid "not working" isn't much help in diagnosing problems.
You really need to ask the people behind "macincloud", whatever that is, but if it has anything to do with your Netgear router. tell people what the symptoms are – error messages and the like – and they may have some ideas. What are you doing ans where does it go wrong?
- kill0708Feb 19, 2023Aspirant
When I open macincloud it is stuck on a screen saying connecting to desktop, configuring remote PC. When I emailed their support, they said it might be an issue with my network firewall, but I don't know how to accesses that.
macincloud is suppose to connect my windows computer to a remote mac pc, so i can use software exclusive to mac.
- michaelkenwardFeb 20, 2023Guru - Experienced User
As microchip8 has explained, you can't get at the router's firewall. But tech people often as used that as a "I don't know what is happening so let's pass the buck" response.
Windows PCs certainly have a built in firewall.
I cant tell if this download is supposed to run on a Windows PC or something Mac.
It doesn't seem like the issue is with your Netgear router.
