OnlineBoy
Oct 07, 2019Aspirant
Netgear Nighthawk R7000 Lan ports giving no internet connectivity
Hello everyone, thank you for coming to my post so I have this weird problem with my Netgear nighthawk R7000, when i connect a laptop or a desktop with windows 10 to my router with a ethernet cable ...
- Oct 07, 2019
1. what modem are you using? (model number)
2. Are you still able to access the router gui from your pc thats directly connected?
3. You've put the firmware on here! good job! if you read about the R7000 on here, you'll see there's been issues with the last several generations of firmware. the most agreed upon stable version is the .42 version. If you do downgrade to it, make sure to do it over a hardwired connection and to reset your device afterwards.
4. do any of the other laptops or desktops have this issue or just the one laptop and desktop?
Oct 07, 2019Guru - Experienced User
OnlineBoy wrote:thanks for helping me man!
here are the awnsers
1. I am using a KPN Experia box v10a (this is a modem router) (the R7000 is configured as a serperate router): its configured in router mode or in AP mode? if you have the Experia running and the R7000 running in router mode it'd put you in a double nat situation.
https://kb.netgear.com/30186/What-is-Double-NAT
2. No, I am only able to connect to the R7000 via Wifi. If you disconnect it from the experia, can you access it over a lan connection?
3. I can try to downgrade, but I dont how i can upgrade the router hardwired, do i need to connect my laptop with an ethernet cable to the WAN port or one of the 4 Lan ports and then flash the firmware or can i connect via the USB port? Your computer should be plugged into the LAN port, not the wan port. I'd disconnect it from the experia and see if you can connect to it.
4. this problem is on all of my devices, even on my small TV
What I'd do first, is check on the double nat situation. Running 2 routers in router mode tends to cause problems/issues. You could put the R7000 in AP mode if you're only using it for the wireless.
OnlineBoy
okey, the firmware downgrade didnt work, should i try next?
- plemansOct 08, 2019Guru - Experienced User
did you reset after the downgrade?
And did you try running it an AP mode? If you're in a double nat, it might have ran fine for a while (some do) and then started acting up.
