zebansho
Jul 14, 2022Follower
Netgear Nighthawk R7000 Question
Hello all, I was hoping for some insight regarding some recent issues with my router and if it is router issue or my abysmal WiFi. Long story short, I have the Nighthawk R7000 and am experienced ...
Jul 14, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart Connect enabled?
What are you advanced wireless settings configured for?
I had my R7000 online for a good week after v.134 came out. Ran very nicely.
I game as well. BO5.
zebansho wrote:
Hello all,
Long story short, I have the Nighthawk R7000 and am experienced sporadic network disconnecting. I have to reset the router around 3-5 times a week for WiFi dropping for no apparent reason. Additionally, I experience significant networking issues playing most video games (of note, Warzone).
I have all home devices on the 2.4 GHz network, with maybe 1 or 2 devices on the 5 GHz network and plug my Xbox directly into the router. I have microwave internet and my WiFi download speed is around 10 Mbps download, and .70 upload (abysmal I know; I live in the country)
From reading through other posts, it appears that upgrading the firmware resolves that issue. However, I currently have the stock .88 firmware, with no upgrades available on the app.
Im considering trying a new router and then switching to literally any other internet providers (only other options here are satellite) but wanted to receive any input from y’all before I do so.
Thank you for taking the time to help.
