farahtung
Oct 22, 2022Follower
Netgear Nighthawk R7000 Question
Hello all, I was hoping for some insight regarding some recent issues with my router and if it is router issue or my abysmal WiFi. Long story short, I have the Nighthawk R7000 and am experienced ...
michaelkenward
Oct 22, 2022Guru - Experienced User
farahtung wrote:
From reading through other posts, it appears that upgrading the firmware resolves that issue. However, I currently have the stock .88 firmware, with no upgrades available on the app.
There have been about a dozen new updates since Firmware Version 1.0.9.88.
This is the latest.
R7000 Firmware Version 1.0.11.136 | Answer | NETGEAR Support
You could update it manually.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
