bw2124
Jan 01, 2017Aspirant
NetGear Nighthawk R7000 VPN Service grayed out
Hi Guys, Networking noobie here. I am trying to enable my VPN service for my laptop and my phones but I see here that the service is grayed out.. Would you guys know what I can do to enable ...
- Jan 02, 2017
If it's in AP mode, try setting it back to router mode, disable DHCP and any WAN stuff (if required) plug into a LAN port instead of the WAN and re-try. It will still be in router mode but acting as an AP...Make sure you give it an IP address so that it can be managed..
netwrks
Jan 02, 2017Master
wongr69
Jan 02, 2017Aspirant
Thanks ...can you point to a thread that does a step by step for DD-WRT flashing on the R7000? I want to load the PIA VPN on the router and I find it so confusing being a newbie.
