retnaosan
Jul 17, 2022Follower
Netgear Nighthawk R7000 vs R8000 in 2021
I recently bought an R7000 and installed FreshTomato firmware on it and I'm very happy with the setup (but could I be happier? I've got nothing to compare to). I bought it to fix an issue with the cr...
Jul 18, 2022Guru - Experienced User
michaelkenward has good points.
You could also look for a mesh system like an older AC orbi that allows you to use wired backhaul and use the same ssid so its got seamless roaming. Tends to be a little more user friendly for when you do move out if the landlord doesn't know how to manage much technology.
