Johndanese
Dec 03, 2020Aspirant
NETGEAR Nighthawk R7000 WiFi Router - LAN gone
I wanted to set up my router for a Mixing board. I went to the settings on browser and updated the Mixer for the LAN IP address 10.10.2.1 The video I watched further stated to change the DHCP start...
Johndanese
Thanks for responding.
In a nutshell this screen ( I took a screenshot before making changes. The Mixer is a Soundesign ui24r. That is meaningless info. All I needed to do was get the LAN IP address from router and config the mixer to that address.. the address was 10.0.0.1 (see picture). The instruction video ( also meaningless ) said to avoid conflicts change the starting IP address to something higher to avoid conflict. Again that is the REASON and the ONLY thing I changed on the router. I changed that to 10.0.0.5 ( highlighted part).
I was incorrect in my original (the mixer was 10.10.2.1) post.
Anyway in a nutshell I changed the Starting IP address on the DHCP server to 10.0.0.5
Now I have no access to LAN settings ( the screen in picture). That is the issue. It’s gone.
Reset button did not bring it back.
Thanks
Thanks
Johndanese
The screen shot shows the firmware version. I did the firmware upgrade prior to doing anything. Latest version. Thanks.
Changing the starting IP address removed the LAN setting page. I spent hours , did reset , scoured internet.
Thanks.
Thanks.
